Old 03-27-2010, 06:03 PM   #42 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
[QUOTE=rmay635703;
Now the trouble is how to build a high voltage cutoff for the solar panel so I can't overcharge. (and no I don't want a 60amp 120v MPPT charger that uses half an amp to handle my 1 amp panel trickle charging my batteries)
Cheers
Ryan[/QUOTE]
Here's the charge controller I am using with my Kaneka 60watt panel:
Xantrex C40 Charge Controller
Since it's only one amp, you may not really need a controller - It would take 100 hours to recharge a 100 amp hour 48V pack..... Just let it pump.
If you plan to leave the vehicle in the sun for days at a time with the solar running, I suppose you should have something. The trouble with those Kaneka panels is that you can't use cheap 12v accessories with them!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
