Old 03-28-2010, 09:32 AM   #50 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The Eco achieves greater fuel economy using a number of features that enhance its aerodynamics, minimize weight and reduce rolling resistance. Details include:
* A lower front grille air shutter that closes at higher speeds to improve aerodynamics and opens at lower speeds to optimize engine-cooling airflow
* The upper grille has more "closeouts" to improve aerodynamics
* A lower front air dam extension, extensive use of underbody panels and a rear spoiler enhance aerodynamics
* A lowered ride height improves aerodynamics
* Unique 17-inch lightweight aluminum wheels
* Ultra-low rolling resistance 17-inch Goodyear tires.
Aeromods plus a 1.4L turbocharged engine and an eco-geared manual tranny should make this an attractive little car.
The first mods I'd do are an engine kill switch, a ScanGauge, and a 100% upper grille block. What other mods do you think it needs?
