Originally Posted by Phantom
Only driving 8 miles will kill the MPG<snip> Also the transmission has two tables one for cold and one for warm in the cold setting it will hold longer before shifting or locking the Torque Converter.<snip>
OR you could try finding someone with a TECH2 (dealer often or a great shop) and see if they can scan and lower the 4th shift and TC lock/unlock about 3 MPH.<snip>
Good luck.
Thanks. In my case, I drive mostly longer distances on the highway. I could possibly change the temp sensor used for the cold setting slightly. (Not a factor this time of year.) Thanks for the tip about the TECH2. ;-]
