Old 01-04-2010, 08:48 PM   #11 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Originally Posted by Thymeclock View Post
If you read my posts you'll see that I already have all the grilles blocked.
my bad dude didn't really read the whole post
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 03-11-2010, 08:14 PM   #12 (permalink)
This may be the reason why. It's the electronic control of the transaxle.
Old 03-16-2010, 10:12 PM   #13 (permalink)
Johnny's Metro - '93 Geo Metro 4-Door Hatchback
90 day: 47.5 mpg (US)
Jetta GLS TDI - '01 Volkswagon Jetta GLS
90 day: 45.83 mpg (US)
The EPA did a study proving that on fuel injected vehicles a clogged air filter will not affect fuel economy, it will only affect horsepower. A K&N won't improve your fuel economy anyway, the DIY warm air intake would be a much better route. Some people prefer filters like Spectre and K&N because they are reusable. However, if you hold them up to the light there are some areas where you can see right through them. Small holes, but still much much larger than the holes you'd find in a standard paper filter. If you plan on keeping the car long term, I'd recommend going with a standard paper filter or an Amsoil Nanofiber Air Filter. They have been proven to filter much better than K&N type filters. This will prevent as much dirt from getting in the cylinders and reduce cylinder wear and help maintain good compression longer.
Old 03-16-2010, 10:48 PM   #14 (permalink)
Originally Posted by JohnNeiferd View Post
The EPA did a study proving that on fuel injected vehicles a clogged air filter will not affect fuel economy, it will only affect horsepower... (etc.)
John,
If you read the entire thread, and particularly my last post, you might realize and understand that the poor city FE has nothing to do with the air filter or anything other than the control of the transmission, meaning the points at which it is programmed to shift. My car is 3 months old with less than 2000 miles on it. It never gets out of 3rd gear until it's over 45 mph.
Installing a different air filter won't help anything.
CLICK HERE
Old 03-17-2010, 01:07 AM   #15 (permalink)
cone filters....
Old 03-27-2010, 11:51 PM   #16 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Only driving 8 miles will kill the MPG since the car will not use the some of the sensors till it has warmed up. Also the transmission has two tables one for cold and one for warm in the cold setting it will hold longer before shifting or locking the Torque Converter.
I'm not familiar with the cars ECM but look around for a tuning program like HPTuners (note they do not have support for your car currently but you could contact them). You would not even have to but the programmer as long as you find some one local that has it.
OR you could try finding someone with a TECH2 (dealer often or a great shop) and see if they can scan and lower the 4th shift and TC lock/unlock about 3 MPH.
Good luck.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 03-30-2010, 12:20 AM   #17 (permalink)
pirate modder
Roger Jolley's Avatar
Location: middle of the middle of the central midwest core
Originally Posted by Phantom View Post
Only driving 8 miles will kill the MPG<snip> Also the transmission has two tables one for cold and one for warm in the cold setting it will hold longer before shifting or locking the Torque Converter.<snip>
OR you could try finding someone with a TECH2 (dealer often or a great shop) and see if they can scan and lower the 4th shift and TC lock/unlock about 3 MPH.<snip>
Good luck.
Thanks. In my case, I drive mostly longer distances on the highway. I could possibly change the temp sensor used for the cold setting slightly. (Not a factor this time of year.) Thanks for the tip about the TECH2. ;-]
Old 06-30-2010, 05:37 PM   #18 (permalink)
Undecided - '96 Honda Civic HX
Last 3: 38.01 mpg (US)
Didn't someone in another thread say that these Korean cars are gonna kick ass in MPG?
Old 06-23-2011, 04:49 AM   #19 (permalink)
Thumbs up Dynamic Cylinder Deactivation Could be a Good Solution to This Thread
Dynamic Cylinder Deactivation(DCD) Could be a Good Soltion to This Thread.
I installed DCD Controller in my 4-cylinder 1.6L AT vehicle like Chevy Aveo,
and tested it in stop-and-go mode around the city block, yielding some 10%
to 13% fuel savings. DCD reduces the engine displacement as well as the
engine power when you don't need too much power during city-driving mode,
resulting a limited accelaration when you start from stop. Such kind of saving
is even larger than that of driving under steady speed, which is around 5% to
9%. So DCD could be best suitable for city-driving. Trying is believing. I have
made a 4-cylinder engineering sample called DCD-440 for you guys to try.
Old 06-24-2011, 12:45 PM   #20 (permalink)
A.J.'s Avatar
The Countess - '03 Mazda Protege LX 2.0
90 day: 25.66 mpg (US)
I'm wondering if your Aveo has DCFO. If so, trying to use engine braking might help your mileage and save you on brake pads and discs.
Chevy AVEO: Adding grille blocks and air deflectors Thymeclock Aerodynamics 11 01-02-2010 05:39 PM
Maker of twin-turbo kit for Corvette claiming massive (167%) city MPG increase. MetroMPG EcoModding Central 36 10-20-2009 12:04 PM
Personal best w/ city and h/w mix - 39.8 MPG Chalupa102 Success Stories 3 10-09-2009 07:36 PM
Review: 2008 Chevy Malibu LT (31.3 MPG) RH77 General Efficiency Discussion 12 05-16-2009 10:07 AM
GM says: next Aveo will have class leading MPG MetroMPG EcoModding Central 17 04-08-2009 03:03 PM
