3 more runs at 3.8 (62mpg), 3.9 (60.3) and 3.8.
Battery is working great. Now if only I could remove the dead/unused cells. What I really need is a custom 14V battery or a set of Saft Ni-cads or a set of Prius cells. Only cheap.
Time to look up plastic welding.
Later in the week I will do some runs with the DC-DC hooked up again to see if this is a summer gas bump.
Wouldn't it be cool to have a set of these running things? Just string however many you need one cell at a time:
A friend of mine actually has a set of similar giant glass cased lead acid batteries that he got as surplus from BC Hydro. He uses them in his home for his micro hydro and solar power storage.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
