Old 03-30-2010, 01:36 PM   #43 (permalink)
Funny
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Have you considered a vacuum for drawing the gas-water mix through a filter? It would allow you to remove the water without wasting any gas. You just need to find a coalescing type fuel filter like the kind they use for bio-diesel. Like this crude drawing that looks like a two year old drew it... though I did. Click image for larger version
Name:	Filtered washed gas (Large).JPG
It shouldn't be all that difficult, and some of the time the filters are able to be reused by dumping out the water.
If you didn't care to use the fuel filter, you could use the same setup with the toilet paper trick described earlier.
American by right
Ecomodder by choice
Hypermiler by necessity
