thanks, your right. the vehicle that everything is going into is a 96 with obd2
the parts vehicle is a 95 with obd1
both are 3 cyl manual models both with the same body styling also.
no wires were cut or anything and everything is labeled so install should go fairly easy. i just dont want to get the 95's motor in to find out it wont run right.
im wanting to swap motors because my 96's motor has 120k miles on it, and the 95 has 85k miles on motor and trans.
the 95's body was completely rusted through so i figured Id use the solid car.
along with turning the parts car into a metro truck last night lawl.
