Old 04-01-2010, 03:29 PM   #55 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
<forehead SLAP>GOSH I wished I'd thought of that!!
Collaborative solutions. That's why we are here.
I love it because it's plug and play. I was expecting a lot of wiring, relays switches and voltage monitoring. Now all I have to do is charge and go. It's partner friendly!
Incidentally this happened by accident. I was supposed to disconnect the DC-DC converter but I forgot. I realized later while we were driving. When I checked the 12V (for easy SCO reference) battery and it showed 11.5 volts under load, I kind of freaked because I thought I had fried the DC-DC with the 14.7 volts. I thought it should read 13.8V. I later tested it by disconnecting the 14V battery and everything worked fine. I then realized that the 12V battery would not read 13.8V with the DC-DC on because of the extra cell. WHEW!
What are the voltage / SOC numbers for those Prius modules? They have a tighter band don't they? I wonder what their SOC will be when they hit 13.8V.
Your extra cell on the Pb battery is a brilliant solution.
Thanks but it's half mine and half Darin who suggested tapping a battery with a screw to tap single cells. I then used this idea to charge one low cell on one of my 12v deep cycles which made me think of salvaging the broken one and tapping/adding one cell.
The one hitch here is the charging. I have a charger that will do the trick slowly but it may not have enough juice to really finish the charge. I still have to test this. Otherwise I will need a 14V battery charger. I wonder if there is any way to adjust an existing charger. Some have pots inside to trim the peak voltage. Hmmm.
My only concern had been whether or not the inverter voltage control would 'suck' electrons out of a higher voltage battery. Have you tried using a current sense resistor to see if there is any reverse flow into the inverter? That will be my first test. <grins>
No. Didn't check this. Don't have any simple way. I guess could install an ammeter. I guess a big diode would solve that if it was back feeding. I don't know enough about electronics to even guess.
I still have to test the FE savings but that will be a simple matter.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
