Old 04-02-2010, 08:49 AM   #39 (permalink)
fatman57
leaving CVT aside - on a manual you could mod it for pulse and glide.........
simply install a switch that turns the injectors on and off - so then you accelerate, turn the injectors off and open the throttle body to full to reduce pumping losses............................then turn on when needed.
I think this would be easier and safer, even if less efficent then a full pulse and glide.
