Old 01-09-2010, 08:11 PM   #31 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by RobertSmalls View Post
The answer is the same as the answer to the question "Is it safe to tow the CVT Insight with four wheels on the ground?". So, I dunno.
And yes, P&G will save gas in any car that can coast with the engine off. The key will be to glide as long as possible (down gentle hills is the only place I bother), and accelerate as efficiently as possible. I think the right way to do that in the CVT is with gentle action on the skinny pedal, so as to keep RPM's down.
Off topic: the 2010 Insight's "EV mode" still has the gas engine rotating, but with all 8 valves closed to reduce, but not eliminate, frictional losses in the engine.
I really don't think the two are the same.
When you tow, you tow for miles and miles... how often do you coast even one mile? There's a huge difference there. The fluid in the bearings isn't going to dissipate that fast, I hope.
Just my opinion, though. I think people look too far into it when they're asking if a vehicle is safe to flat-tow when they're considering EOC.
Old 01-09-2010, 11:34 PM   #32 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
To continue off-topic (briefly) I have been searching for more details (without success) on how this engine works. Is there a good source you recommend? Thx...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 01-10-2010, 07:16 AM   #33 (permalink)
First you have to understand the average speed is the critical component. You can get 80 MPG in a lot of cars if your average speed is 22 MPH.
Second in regards to a CVT Insight. All last summer I managed close to 80 MPG in my daily 38 mile round trip drive after warming the engine up. My best was 83 MPG one way, while averaging 40 MPH through over 40 traffic lights.
The CVT will climb very shallow grades at over 55 MPG, with acceleration that is very very gradual, measured in several seconds per MPH increase in speed, while climbing a very very slight grade, measured in a few feet per 10th mile.
Then on the very slight downgrades the instantaneous mileage will jump to 125-150 if you allow the car to very very slowly decelerate. The other traffic on the road will hardly notice the changes in speed because they are microscopic.
The best summertime mileage I got in the CVT averaging 55 MPH was 70.2 MPG for 577 miles in one day. Mostly daylight, with absolutely no accessory loads whatsoever.
I don't do engine off coasting in the Insight, not interested in wrecking a 5k transmission.
regards
Mech
Last edited by user removed; 01-10-2010 at 08:38 AM.. Reason: should be MPH instead of MPG
bwilson4web (01-11-2010)
Old 01-10-2010, 08:23 AM   #34 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
RH77
I got that tidbit from some car magazine, but there's always Honda's website.
You can try cruising the forums at InsightCentral, but the modifications made by current 2nd gen owners tend to be window tint, stereos, interior lighting, blah blah blah.
Old 01-10-2010, 05:42 PM   #35 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
I found the same on specialty sites: a whole lot of nothing. I did find a helpful video on the Honda site that describes the LDA-Series 3-Stage VTEC and IMA system (for what I assume is for both the HCH-II and 2010+ Insight). It didn't discuss the dual ignition per cylinder, but there is lots of documentation elsewhere. The search terms of "Insight" and "L13A" or other engine terms yielded a bunch of fluff. I only assumed the Civic setup was similar, which apparently it is.
Unfortunately, most of the Insight's details are marketing ploys, blogs, and games. It was refreshing to finally figure out how the "EV" mode worked! (thanks for the re-direct).
Apologies for the "off-topic" folks -- the thread is now resuming regularly scheduled programming, already in progress...
RH77
_
_
Old 03-31-2010, 11:50 AM   #36 (permalink)
coasting is fine in most modern vehicles as when you take your foot off the pedal as long as the revs are above idle no fuel will be injected into the cylinders...................just leave the car in gear and take your foot off the pedal.
I have a CVT and it has a wet clutch. Coasting should be fine in it as long as it is in 'drive' - it depends on the gearbox but in my case this allows both cones to rotate. This will turn the engine over but also pump oil onto my primary cone (which is connected to the engine side) - and you really do want a lubricated cone! If the cone were to remain static with no oil that could easily mean damage being done............
Old 03-31-2010, 12:35 PM   #37 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
If it's in Drive, that's not coasting. You're describing fuel-cut engine braking. That's useful in it's place, like coming up to a red light or down a mountain. It's not useful for Pulse & Glide.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
Daox (03-31-2010)
Old 03-31-2010, 02:04 PM   #38 (permalink)
my apologies - I stand corrected!
I think in terms of a CVT the engine will need to turn over to drive the hydraulics, so it is necessary to keep it in drive. This again depends on the design of CVT.
unless of course you install a manual clutch inbetween the gearbox and the engine but that is a different story all together!
Old 04-02-2010, 07:49 AM   #39 (permalink)
leaving CVT aside - on a manual you could mod it for pulse and glide.........
simply install a switch that turns the injectors on and off - so then you accelerate, turn the injectors off and open the throttle body to full to reduce pumping losses............................then turn on when needed.
I think this would be easier and safer, even if less efficent then a full pulse and glide.
Old 04-02-2010, 11:56 AM   #40 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
Wow, I never thought of turning off the injectors and flooring it! I have just been mostly just pushing it into nuetral to coast in traffic and using the kill switch when I know I'm gonna sit at a light when I stop.
Getting 45 MPG at 207 MPH .... can you pulse and glide an airplane? MetroMPG Hypermiling / EcoDriver's Ed 43 03-03-2010 02:20 AM
Pulse and Glide Your Prius for Super Fuel Economy SVOboy EcoModder Blog Discussion 7 08-13-2009 12:48 PM
