Old 04-02-2010, 10:37 AM   #13 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The info you need is somewhere on TeamSwift.net, but basically I think you need to change the oil pump and pan to swap the crank sensor over to the '95 engine. What's wrong with the '96 engine? 120k miles is nothing. Just use it if compression is good.
