Originally Posted by MPaulHolmes
I'll do that! Man, 4 soldering irons. This guy wasn't messing around! ya!
The trick with soldering is to think of thermal mass. If you are trying to heat up something that is going to suck up a lot of heat your soldering iron needs to have mass, not a matter of being hotter but having more stored energy. Otherwise the target sucks out all the heat from the iron before it is hot enough to solder.
Also with circuit boards you want this all to happen relatively quickly, having to much heat in the PCB for too long will weaken the structure. You will see this with fine track work, the tracks will start to lift from the board.
