Old 04-06-2010, 08:08 AM   #10 (permalink)
Ford Man
Originally Posted by daring4 View Post
Not sure that NC ambient temps are close to Az summers where we have hit 122! Doesn't your car have a fan switch that will turn on at a certain temp? Mine turns on at 205 but I have a 185 deg that I might put in soon if I need a little extra cooling. 230 isn't good for your engine! My fan is a two speed unit that runs kinda slow if the A/C is on then faster when it hits 205.
AZ temperatures get a quite a bit hotter than NC, but NC has a much higher percentage of humidity, but I'm not sure what effect that has on engine temperature if any. Most summers our highest temperatures will run 100-105* F with the normal highs being 90-100* F. As for the higher temperatures I run the engine at, that car has 506K+ miles on the original engine without a rebuild or even having the head off of it. Also the presurized cooling system on a car raises the boiling temperature, a cooling system running 15psi raises the boiling point to 250* @ sea level and most cooling systems run 15-17 psi on their cooling system.
I don't think you'll have any problems with overheating if you have good air flow from underneath your car and your cooling system is clean and filled with 50/50 water/anti freeze, but as I said before I'd keep a close eye on it in city/stop and go traffic until I was sure.
