Old 04-07-2010, 06:25 PM   #13 (permalink)
hotrodfeguy
Yup cut mine down and love the ride. I notice a bit during 65MPH big dips, But love the lowering, I think its well worth doing just for the cornering improvement. But exactly one ring of the coil was taken out so everything lines up in the same places IE the spring holding points.
Thanks for the advice on the Cam Mullet, So you did both the advance and the cam. Was considering one or the other but not both. Just in all my years with cams when you move stuff that much doesnt seam to work as well. Cause from my understanding the XFI has +6 in it already from factory then add the +10 gear and your +16 ahead of the crank. Just seams like alot to me.
94 Geo Metro 52-56 MPG
06 Jetta TDI 46-48 MPG
