Old 04-07-2010, 08:41 PM   #188 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
What gauge wire to run?
I think 18-20 ga. wire might be ok but that's just a wilda** guess.
Anyone here have a better informed suggestion?
It should fit the crimp connectors for the 4-pin white nylon connector and carry the 'load' easily.
And, what rating fuse? Recommendation is to run off constant power so makes sense to me to fuse it. I already have a good tap at the battery so won't be using an existing fuse panel.
I have the preassembled MPGuino from opengauge.org with the 3 vertical buttons and white 4-pin connector.
Coast long and prosper.
