Old 04-12-2010, 03:32 PM   #127 (permalink)
ai_vin
Originally Posted by zoltanbod View Post
Hey Robert,i just found some research results that might interest you.University of Wisconsin-Madison,led by professor Rolf Reitz have come up with an engine that combines gasoline and diesel to get the best of both worlds.Using fast response fuel blending they have achieved 53% thermal efficiency! The special mix lowers engine temperature by as much as 40% drastically reducing the amount of energy lost to waste heat.There you go now it is not unheard of.This application was done on a diesel engine,they claim by applying it to a gasoline engine the fuel economy potential improvement would be even larger.Check it out.
Well if you're willing to concider diesel you may want to check out Kubota Canada; KUBOTA.CA - HOME
They make a number of small 2-3 cylinder engines; Kubota Canada : Manufacturer of compact diesel tractors, construction equipment, agricultural equipment, power washers and engines. which have already proven usable in cars; XR3 Hybrid Personal Transit Vehicle: A 125 mpg Plug-In Hybrid Three Wheeler You Build From Plans
