This is too cool! You'll have it ready for GGP, right?
Originally Posted by Christ
making the tach work will require a "healer" of some sort, because the tach is meant for a 4 cylinder, not a 3. It gets it's signal from the igniter in the dizzy - I believe the green wire - so you might have to figure out about using a resistor or something to keep it accurate, but I'm not sure about that. It might "just work".
I'm pretty sure I've seen a thread at teamswift about how to mod a tach from a 4-cyl suzukiclone to make it work with the 3-cyl.
