Yes I unpluged and repluged it. vss Pulses/mile reads 8200 and vss Delayms reads 128 .Distance on screen stays on 0 miles. The unit was working normally then when I stopped I noticed the screen did not make sense ( blocks and ? marks ) then when I reset the speed /distance had a problem. I had been using v74 so I changed it to v75 and still same problem. Thanks
