Code p0420:
Causes -
A code P0420 may mean that one or more of the following has happened:
* Leaded fuel was used where unleaded was called for
* An oxygen sensor is not reading (functioning) properly
* The engine coolant
temperature sensor is not working properly
* Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
* Retarded spark timing
* The oxygen sensors in front and behind the converter are reporting too similar of readings
Possible Solutions -
Some suggested steps for troubleshooting a P0420 error code include:
* Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
* Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
* Inspect the downstream heated oxygen sensor (HO2), replace if necessary
* Replace the catalytic converter
I hope those solutions help, you may be able to clean out the cat with an additive, I can't remember how I fixed it. I know I've replaced the O2 sensors... Removing the passengers seat to change the rear one is a little tedious, but not hard - doesn't take much longer than the typical splice technique.
American by right
Ecomodder by choice
Hypermiler by necessity
