Old 04-19-2010, 09:10 AM   #80 (permalink)
Funny
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by ShadeTreeMech View Post
I don't mean disrespect, but can you prove or know where to prove ethanol causes problems for the engine?
It doesn't show disrespect, it just shows you're trying to weed out any false information.
I have been following this thread with interest since it first started. The reason I was interested was the multitude of instances I have been witness to as a small engine mechanic (lawnmowers, snowthrowers, chainsaws and the like) on the side. All of the owner's manuals mention to get gasoline without ethanol where possible. ALL of them. Most of the small engine repairs I have made are fuel related, a high percentage of which are carburetors clogged with waterborne goo or fuel filters/gas tanks with water in them. This was not the case until the local government mandated ethanol in my area. Before then it was usually a spark plug or carbon deposit problem. So I would err on the side of Nerys in this arena. At least as far as the repairs are concerned.
Fuel pumps definitely do not like water. Because ethanol forms an azeotrope with water, there is NEVER (well, almost never - there is a form of super anhydrous ethanol that exists, but that immediately absorbs humidity out of the air.) What that means is that the ethanol is never without tag-along water, on the order of 4-5%. So when you are putting E10 into your tank, you are putting water into your tank also. Lets look at the math:
Assuming the Ethanol contains on average 4.5% H2O-
If you put E0 in your tank: H2O = 0 of total volume
If you put E10 into your tank: H2O = 0.45% of total volume
If you put E85 into your tank: H2O = 3.8% of total volume
The better choice if you were looking to dilute gasoline would be Methanol, It doesn't form an azeotrope with water and therefore comes in an anhydrous form relatively cheaply. Problem is you can't make it from corn... But that is another argument.
Rant Over.
American by right
Ecomodder by choice
Hypermiler by necessity
