Old 04-24-2010, 07:48 AM   #1 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Civic - ? Removing plastic cover cap over injector wires?
Has anyone removed this cover cap, and how?
I found 2 release tabs on the top surface near the rear, and one on the driver's end. Those loosen it some but its still not free.
'97 Civic HX: SOHC with VTEC.
It's for a fuel cut switch. A single wire will run from dash switch to control a new relay in engine bay. Relay will open or close the always hot wire going to the injectors. The injector grounds are switched by the PCM (computer).
Coast long and prosper.
