Old 04-28-2010, 11:50 AM   #4 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I don't know about your particular Mazda diesel but I cut off the muffler on my VW diesel and replaced it with a straight pipe, with no real increase in noise. The cat-converter and the turbo quiets the exhaust noise nicely. It may make the turbo more efficient but I didn't see any significant gains in mpg or power. I think the upgraded exhaust may be more of an issue if you are boosting the power on your diesel than it is for high mpg at light engine loads. I deleted the muffler primarily to make more room for a belly pan install.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
