Originally Posted by mcudogs
The latest firmware works well on these boards but as you said it doesn't implement the new hardware functions.
Hi Don,
Thanks for your reply.
To understand you correctly, your using the V1.11b firmware on your Rev.D PCB right now?
The extra I/O hardware you added to the Rev.D PCB still needs to be programed into the current V1.11b firmware?
Was I correct about the new I/O you added to your Rev.D PCB?
1. Motor Speed Sensor
2. Battery Voltage Monitor
3. Cap Pre-Charger
4. Cooling Fan
5. Extra A/D
I have a question about your "etched" Power PCB. What is the weight of copper you are using on your G10/FR4 PCB?, 2oz, 3oz, 4oz, etc.....
Thanks again,
- Mark
