Old 04-30-2010, 06:24 AM   #3377 (permalink)
mcudogs
Originally Posted by sawickm View Post
Hi Don,
Thanks for your reply.
To understand you correctly, your using the V1.11b firmware on your Rev.D PCB right now?
The extra I/O hardware you added to the Rev.D PCB still needs to be programed into the current V1.11b firmware?
Was I correct about the new I/O you added to your Rev.D PCB?
1. Motor Speed Sensor
2. Battery Voltage Monitor
3. Cap Pre-Charger
4. Cooling Fan
5. Extra A/D
I have a question about your "etched" Power PCB. What is the weight of copper you are using on your G10/FR4 PCB?, 2oz, 3oz, 4oz, etc.....
Thanks again,
- Mark
Mark,
Yes I am using the v1.11b firmware now. All of the version c inputs and outputs are using the same pins as this version. The extra hardware still has to be programmed in to a new version of the firmware.
The extra functions are
3. A 2nd mosfet driver to drive a 12v load
4. Configurable Input A/D or opto isolated digital
The power board is 4 oz copper. Where the Cu is thinnest between the diodes and mosfets there is no solder mask and I run a thick bead of solder to improve the current carrying capacity.
Don
