Old 05-01-2010, 07:28 AM   #2 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I'd say you're right on both concepts. That is, reducing engine rpms and getting a bit of a wheel skirt effect. You'll see some small fuel-thrifty cars where they line up the tire sidewall with the body work in an attempt to get a smoothed air flow.
You could consider changing the tranny or rear end gearing instead of changing the tire diameter. I don't know what the options are for your truck but there are usually several gear combinations out there to be had. The cost might be in the same range as a set of tires.
Coast long and prosper.
