Old 05-01-2010, 03:45 PM   #101 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Shouldn't tire wear be a factor as well?
For instance the 4 tires on my jeep are about 1000 dollars a set.
I know that on other all terrain tires over inflation
will grind the center away
You don't know that, you think that. It's not true. Bias ply tires could do this but steel belted radials do not. Steel belts and carcass design help to keep the tread patch flat. Many ecomodders have shown their tires after years of service at high pressure without the centre wearing out first. Higher pressure increases tread life.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Last edited by orange4boy; 05-01-2010 at 07:43 PM.. Reason: Fixed bad description of tire construction
The Following User Says Thank You to orange4boy For This Useful Post:
Christ (05-02-2010)
