Old 05-01-2010, 07:36 PM   #104 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I think the reason this article has been pulled is that it is full of misconceptions and does not back up the things that are put forth as “facts”.
The article is obviously an informed opinion and presented as such.
At the beginning of the tread is a list of documents supporting my points. Perhaps you should read them.
Even the NHSTA thinks over inflation is not a safety issue.
Sorry, but the steel belts are neither radial nor circumferential. They are at about a 15° angle. And while the belt slows the “arching” affect down, it does not prevent it from happening.
That's true, I'll point hat out in the article. Nevertheless, tires inflated to max sidewall do not wear out faster in the centre in my and many other's experience.
We have posted the best information we can find including studies but I still have not seen a study giving solid evidence of danger, reduced traction, increased wear or most of the other myths trotted out about max inflation. PERIOD. Find them and post them if you can. I am open to it.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
