Old 05-02-2010, 04:58 PM   #111 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
My toyota pickup (1989) called for 35psi, this would make the rear of the vehicle harsh, and unpredictable.
I assume you meant when your pickup bed was not loaded.
We are mostly talking about passenger cars here but I agree that pressure should be proportional to load as this makes sense. I run lower pressure in my rear tires than my front as my loading is not 50/50 front / rear.
I am not espousing over inflation in this thread. Extreme over inflation and low loading may cause the centre to wear faster but max sidewall and proper loading does not.
I am not saying there is no relationship between inflation pressure and traction but that it is not as drastic as many people believe and running higher pressures, within reason and up to max sidewall, is safe and has more benefits than downsides.
Added: Tire pressure should be proportional to load, ie: a car with 55% front 45% weight distribution should have slightly lower pressure in the rear tires. One suggestion is to use the same ratio as the placard.
Benefits of max sidewall pressure in my opinion from what I have learned:
1) Lower heat build up. Reduced risk of accident or rollover resulting from loss of control from heat related tire failure.
2) Reduced wear
3) Slightly increased peak traction, slightly reduced sliding traction. Slightly reduced stopping distances (may have to do with increased traction)
4) Reduction in hydroplaning (onset of hydroplaning happens at a higher speed)
5) Reduces slipping in snow* (depending on conditions, sometimes lower pressure is better)
6) Increases tire responsiveness in cornering.
7) Reduces body lean in cornering, improves steering feedback (subjective)
8) Reduces fuel consumption
9) Reduces steering effort
Downsides to max sidewall:
1) Slightly harsher ride quality.
2) May increase rollover tendency in already rollover prone SUVs in certain conditions.
3) Harder on suspension components in rough road conditions
4) Slightly increases risk of tire bruising or failure from impact with blunt objects.
I have been updating this list as I learn more just so you know I am open to the most credible information.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
