Thread: Ben's Elec-Trak
Old 05-02-2010, 09:40 PM   #96 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Work on the transmission!
Since today was a meeting of the Milwaukee Electric Car Club, I took my transmission with and brought it to the meet.
The Steves helped me take the transmission apart. Ok, they did most of the work. I watched, learned, and took lots of photos.
I am glad that I hosed down the transmission bolts with penetrating oil the other day. It made a huge difference in taking everything apart.
Oh, I also learned that I added WAY too much oil before. That was messy to drain out....
Here's the tranny when we first got it open.
The bronze bushings around the drive shaft was very worn. To get at the other side drive shaft, we would have to take out all the gears inside.
We used a long piece of pipe to pound the bronze bushings. (That's one thing I didn't get a photo of. My hands were full of pipe and hammer!)
I took photos as we pulled parts, and we laid them out left to right on cardboard to keep track of them all.
Once we got down to the driveshafts and differential, it was easy to see that there was quite a bit of wear.
We even took the differential apart to take a look inside. Would it be possible to make new driveshafts? Yep, we could do that, but would have to spine the ends, and do a bunch more work. Rain was threatening, and in the end, we decided it would be best to simply reassemble everything.
We reused the bronze bushings from the outside (which were less worn) for the inside position. I am going to buy new bushings for the outside, as well as new oil seals for around both driveshafts, the pulley shaft, and brake shaft.
Re-aligning all the parts to get it all back together was a bit of a pain. We also gasketed the stick shift and the main case seal.
I hope I can still install the outer bushings and oil seals without pulling the whole thing apart again. If I have to, I have to, but for now, I kinda needed to get the whole thing together so at least I wouldn't lose any parts!
As it was, I DID have to consult one of the digital photos to make sure one of the parts was in right. (Which it wasn't!)
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
