More terribly interesting information:
The chart shows the Minimum inflation pressures at certain loads. Then it gets very interesting.
I point you to note #3
Cold inflation pressures may be increased above those applicable to the tire loads up to the maximum marked on the tire with no increase in load.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
