Old 05-04-2010, 02:47 PM   #27 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Ryland View Post
I don't know about straight 30 weight, but I can say that I haven't had any trouble using 0W30 oil in both my 1981 civic and my 1993 civic, the Honda branded MTF is also supposed to be safe, $7-10 per quart last I checked and I'm not sure the life span of it.
Other thing with the CRX HF is tires, it's supposed to take the same size as the civic vx if I remember correctly, 165/70R13 if I'm not mistaken, hard to find size but a size that you can get in low rolling resistance from tirerack.com
Also, your PCV valve, I think is under your intake manifold, hard to get to and seldom checked or changed.
10w-30 worked fine in my 1984 Civic Wagon.
I'd clean the PCV valve out with carb cleaner or get a new one from Honda. I once tried a Fram valve and it failed the factory manual's test about 50% of the time. I had pretty good luck getting the valve out of the breather chamber just by pulling on the hose.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
