Old 05-03-2010, 11:33 AM   #21 (permalink)
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
I have RedPepperRacing's copy of a service manual:
87 Civic Factory Service Manual
I'll dig into it. That's strange, to say the least.
Edit:
Well I'll be... Thanks for the info Ryland!
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 05-03-2010, 01:43 PM   #22 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Don't try straight 30 weight oil in the tranny. I did that in an '85 Accord. It was easy to crunch a shift when cold. Even in their acceptable temperature range for 30 weight oil. I have Honda's MTF in the '91 Civic I'm driving. Didn't shift any better than it did with whatever was in it before.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 05-04-2010, 12:36 AM   #23 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I don't know about straight 30 weight, but I can say that I haven't had any trouble using 0W30 oil in both my 1981 civic and my 1993 civic, the Honda branded MTF is also supposed to be safe, $7-10 per quart last I checked and I'm not sure the life span of it.
Other thing with the CRX HF is tires, it's supposed to take the same size as the civic vx if I remember correctly, 165/70R13 if I'm not mistaken, hard to find size but a size that you can get in low rolling resistance from tirerack.com
Also, your PCV valve, I think is under your intake manifold, hard to get to and seldom checked or changed.
Old 05-04-2010, 01:19 AM   #24 (permalink)
Tires aren't a problem, have a friend in said dealership that can find them. Does the wheel/tires department.
Old 05-04-2010, 09:47 AM   #25 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
This chart may make the "motor oil in the tranny" idea seem less bizarre:
I guess Honda just wanted a tranny oil thinner than any gear oil on the market.
Old 05-04-2010, 09:58 AM   #26 (permalink)
And I guess with such low power motors and light weight cars, they really don't need the heavier oils.
Old 05-04-2010, 02:47 PM   #27 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
10w-30 worked fine in my 1984 Civic Wagon.
I'd clean the PCV valve out with carb cleaner or get a new one from Honda. I once tried a Fram valve and it failed the factory manual's test about 50% of the time. I had pretty good luck getting the valve out of the breather chamber just by pulling on the hose.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-04-2010, 03:14 PM   #28 (permalink)
Will do.
At any rate, carb gasket goes in. Waiting on the ebay seller to ship the corner marker so this thing can goto inspection..
Old 05-05-2010, 11:10 AM   #29 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Nice build thread! Good to see an unmolested CRX stay that way and running in top shape and looking good to boot!
Old 05-12-2010, 01:15 AM   #30 (permalink)
Should be on the road this week! The Civic side marker finally came in, and got it to fit for the time being (will get a properly fitting CRX one when it pops up, but it needs to pass inspection now) and we'll just have to make a carb gasket, none seem to exist.
Which is excellent, because I'm having to fill up about $90+ a week at the moment between school and work. Thankfully, finals end this week, so it'll just be down to work for the CRX. Be able to see what it's really capable of.
1991 CRX hf RandomFact314 General Efficiency Discussion 26 08-13-2009 10:58 PM
CRX HF Questions MadisonMPG EcoModder Blog Discussion 8 08-13-2009 10:53 PM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
1987 crx hf alternator control module watson Off-Topic Tech 2 03-26-2008 12:35 AM
