Old 05-06-2010, 01:10 AM   #95 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The Honda main relay is a complicated solution to a simple problem. I carry two spare main relays in the Honda I'm driving. Suzuki just used two separate standard relays.
The beauty of the Metro wiring is that the engine harness runs from the engine to the ECU with a couple of plugs that connect to the rest of the car. Using the Metro harness is the easiest thing to do in this case. It's practically a standalone TBI system. But the ECU will end up on the driver's side, unless you modify the harness.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
