Old 05-06-2010, 07:54 PM   #24 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by moorecomp View Post
Under the water pump housing, the metal plate with the semicircular cutout could be remade without the cutout and installed with a full gasket under it. Liberal use of sealant and removal of the impeller and you should be good to go.
You're familiar with this motor! (Or is that a common pump housing approach?)
I thought I was going to take exactly this route. But it turns out the water pump can't easily be sealed to the water intake passage. It's immersed within a flooded "compartment" - the passage actually opens inside this area, beside the impeller housing. The pump is only actually sealed on the output side (to a valve that leads to the ICE's water jacket).
Originally Posted by lightflite View Post
If its any help with the power required, boats like this are (used to be) powered by British Seagull longshaft outboards. Altho plated as 4 HP, I understand they measured as about 1/2HP - but they had huge reduction and swing a large coarse prop. What they lost in power and honesty they gained in propulsion efficiency.
True, true, good points. I do know that this boat's 15 horse twin is uncommonly big - most of the other boats of this size around here get by just fine with 7 horse singles (gas or diesel), or 9 hp outboards.
And there are still a few people who use boats like this with no motor at all. It just takes away a safety measure and forces you to be more thoughtful about using the boat.
For your relatively short running time you could probably also add more volts to your small motor to get the required performance - and watercool it if necessary for survival
Water cooling it at this point is out. Too ironic!
But overvolting is always an option.[/QUOTE]
