Old 05-06-2010, 11:09 PM   #97 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The MAP sensor wiring should be in the Metro's engine harness. And the MAP sensor only has one hose connected to it, along with a 3-wire plug. Made by Denso.
Will you be at the GGP even if you don't get it running? I have a '92 XFi harness that I got with my XFi engine. The guy had converted the harness for using the engine on a generator. So the harness is in theory, modified to run the Metro engine outside of a Metro. I have not tested the harness or checked if it was done correctly, but I think he said he had it running like that. I can bring the harness if you want it.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
