Old 05-07-2010, 10:26 AM   #109 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I dunno, a relay's a relay. There's not much to them, so they should be compatible. There's even a diagram on the side of each relay to explain what's going on inside:
So as log as you attach the wires to equivalent legs, you could use Ford relays in your CRXFi if you wanted to.
