Thread: Underbody Trays
Old 05-07-2010, 04:04 PM   #3 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
rear diffuser
Drilling holes in the bumper cover has come up before on here. The consensus seems to be that the holes still increase turbulence. You should strive to make things smooth and tapered like a dolphin or a seal's shape. Deezler has built a nice rear diffuser which should reduce lift and reduce drag at the same time.
http://ecomodder.com/forum/showthrea...ad-7868-4.html
If you are going to cut up a bumper cover, this would be a better way to go.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
