Old 05-10-2010, 08:18 PM   #10 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Another aspect -
The engine cooling effect of adding engine heat to the a/c'd cabin air can be a good thing if it's running a bit hot.
On my ScanGauge, I've seen this add just enough engine cooling to the system to bring the ECT down into its normal range, when I forgot to remove some grill blocking that wasn't appropriate for the weather.
If you have a digital engine temp gauge (ScanGauge includes one) you can see it happening in detail.
Coast long and prosper.
