SGII MPH can be adjusted for tire size.
Originally Posted by ShadeTreeMech
why would the MPH readout on the scanguage be more accurate than the speedo due to oversized tires? The VSS doesn't "know" when the tires are a different size, so would simply read the factory settings, unless the SG has a GPS chip in it...
In setup you can set the MPH factor, for example mine is set to 6% as my current tires are 6.3% over sized.
This same setting also adjusts the miles traveled, mpg gauges.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
