Old 05-11-2010, 09:46 PM   #21 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
why would the MPH readout on the scanguage be more accurate than the speedo due to oversized tires? The VSS doesn't "know" when the tires are a different size, so would simply read the factory settings, unless the SG has a GPS chip in it...
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-12-2010, 09:13 AM   #22 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
SGII MPH can be adjusted for tire size.
In setup you can set the MPH factor, for example mine is set to 6% as my current tires are 6.3% over sized.
This same setting also adjusts the miles traveled, mpg gauges.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Old 05-12-2010, 07:15 PM   #23 (permalink)
Basjoos Wannabe
AH ok so there is that utility. Very nice. Makes me want to get the SG even more!
Old 05-18-2010, 01:46 PM   #24 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.09 mpg (US)
MPG- instant mpg
AVG- trip MPG
RPM- RPM
FWT- Temp
Old 05-26-2010, 10:49 PM   #25 (permalink)
Basjoos Wannabe
I got a ScanGuage now and love it! I had to make use of the XGuage feature and add the HP function. I don't think it's very accurate (said my Maxima had 217 HP under hard acceleration up a hill when it is rated 190 from the factory) but it's interesting to see how little you can get the H down to while cruising.
So far I have
GPH
MPG
HP!
TPS
It can become very distracting I've noticed! However, it would seem that the car shuts down the fuel while coasting over 1500 rpm, so :thumbsup:
Old 05-26-2010, 11:11 PM   #26 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
That's estimated gross horsepower, which isn't power at the crank, but power at the piston. It read as high as 190HP in my 135BHP Subaru. GPH is more useful.
Old 05-26-2010, 11:19 PM   #27 (permalink)
Basjoos Wannabe
I think the HP is merely a gauge for giggles. GPH is definitely useful; it told me the comp shuts down the fuel during coasting.
Old 06-05-2010, 06:22 PM   #28 (permalink)
Lex Luthor - '10 Lexus HS250h
90 day: 70.18 mpg (US)
Just installed my SG2 today and am trying:
RPM-my hybrid has no tach so this tells me when the ICE is off
MPG
TPS
GPH-this also lets me know when the ICE is not running (before the SG I never knew when my ICE was off or on, so this thing is great)
Will experiment with these 4 and see where I go from there.
Old 06-08-2010, 12:50 PM   #29 (permalink)
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
I've had my SGII for a couple years now in three different vehicles.
The two gauges that have remained on the display all along...
TPS
MPG
The other two gauges have varied and I just changed them again this morning.
First was...
IA Temp
MAP
Then...
IA
WT
Now...
LOD
GPH
I liked using the MAP setting as I used it as something like a vacuum gauge. The '02 Blazer was the only one to supply this, my '02 Miata and my current '10 Cube do not.
Old 06-08-2010, 07:11 PM   #30 (permalink)
imported Appalachian
Yoda - '97 Toyota Corolla Base
90 day: 30.51 mpg (US)
She-Ra - '03 Honda Accord EX
90 day: 22.91 mpg (US)
Thor - '04 Toyota 4Runner SR5
90 day: 18.26 mpg (US)
1997 Toyota Corolla, 3 speed automatic
I use:
MPG
AVG
MPH (My dash speedometer is way off, Scanguage gives me the right reading)
TPS
What gauges do you use on your scangauge? regor EcoModding Central 15 03-22-2013 05:56 PM
Stock Temperature Gauges jcantara Instrumentation 24 05-27-2010 12:26 AM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 07:31 AM
Three most useful gauges? JJW Instrumentation 35 10-24-2008 04:31 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 04:26 PM
