Old 05-12-2010, 08:49 AM   #17 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Too bad they dont make/sell ecommoder body kits!
Mimicing the roofline of the contemporary Prius or Insight would put you in the money.
Since 'appearance' is an issue,you might search for a 'production' rear spoiler ( from any car ) which would fit the trunklid of the Camry,which would both extend the 'length'of the trunklid,and also terminate at a higher elevation at the trailing edge than what you have.
Consider,that for a modern day CIVIC sedan,to approach the low-drag roof of today's Insight requires a rear spoiler 130-mm high,reaching 65-mm further back.
So the spoiler would need to be 5+ inches high and extend 2.5+ inches further back then the current trunk lip. That would like totally "ricer" on a Camry!
Nothing happening this week as I am busy stuck on more mundane tasks.
I did order 15" pizza pans I hope to install before my next 500-600 "commute".
The local Selectman election should end some free coraplast hopefully will be available.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
