Old 05-12-2010, 05:54 PM   #28 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Andrew - too bad it wasn't as easy as pouring sealant down the cooling passage. Unfortunately, the forward/reverse shift mechanism also runs inside the passage, from inside the hull down to the gear case. Not so simple, this one!
Update: the boat is still floating! (Sending this message from on board, actually.)
I haven't yet opened the top to see if any water entered the cooling passage from below.
Also haven't done any more e-motor fiddling, not counting moving the boat a couple of times with the trolling motor (once to go back to the harbour where I launched in order to put up the mast).
The Green Grand Prix last weekend, and the EV Expo this Saturday tinkering time is at a premium.
Next week should see some action on this project.
