It was pretty bendy stuff, not too terribly rigid. It was my fault it cracked anyway. I wasn't careful when I drilled the mounting holes into it, and it cracked right then. It held up just fine for a while, but the crack slowly grew. I also didn't like that it slid around a little bit and you could see dirt and such building up behind it as it scratched away at the grill under it. I figured I'd nip any more scratching like that off at the bud since I do plan on selling the car.
