Old 05-17-2010, 11:16 PM   #13 (permalink)
sc2dave
Originally Posted by bgd73 View Post
the radiator is in use when thermostat is open. That means engine is full warm on the cold fuel..before warming the fuel. This is silly....I hope you see why.
toyota 22r...the tank is soft mounted. I can see why you would want to make a quest to make it lively (warm)... I am on this gas subject recently with an old subaru welded into crazy strong.. the hard mounted tank needs to be urethan strapped to calm down hard resonance (way to active...proof in the venting) warm the carb somehow, leave fuel alone til last second before engine..heat riser ideas galore.
ALL your gibberish is "silly... i hope YOU see why."
