Old 05-18-2010, 07:44 PM   #3 (permalink)
user removed
The CVT in my wife's Rogue is probably similar to your Versa.
Accelerate at 14-1600 RPM to your speed, then you can do mini pulse and glides.
Very gradual acceleration to 5 MPH over average, then let it very gradually loose speed to 5 MPH below average. If you have any grades try to maintain speed up the gradual inclines then use the downhill portion to use minimum throttle position to very gradually loose or maintain speed.
Try to keep engine RPM in the range of 1200-2200 RPM.
regards
Mech
