Old 05-18-2010, 11:30 PM   #7 (permalink)
stevet47
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
Originally Posted by Old Mechanic View Post
I managed 33.25 MPG on one trip in her Rogue. I think your Versa is the 1.8 engine, or the 1.6.
I'll bet when you get it down pat in warmer temps you should be able to beat 40 MPG average.
Go to sidewall max pressure on the tires, probably about 44 PSI.
regards
Mech
Thanks. Yes, it is the 1.8L. And I aired up the tires to 44psi for this 2nd tank.
40mpg is my goal. Hopefully with some aeromods I can reach it.
