Old 05-20-2010, 08:04 AM   #122 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Enough throttle cable slack? Vacuum leak? Plug all open tubes on the intake manifold. Don't play with the throttle stop screw unless you're sure it's been moved. If it looks like the throttle butterfly is closing all the way, leave that screw where it is. There's an idle speed adjusting screw on the throttle body, but it's really for fine adjustments. It normally hidden by a little black rubber plug. It's on the driver's side.
My 1990 Civic Wagon service manual shows a blue wire for the tach. Whether it's green or blue, it should be hooked up to the brown wire coming from the noise suppressor. That should hopefully get the tach working.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Wonderboy (05-20-2010)
