Old 04-02-2008, 04:21 PM   #4 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Mild Hybrid
Is this along the lines of a "Mild Hybrid" -- although it probably wouldn't be powerful enough to run the accessories and turn the crank at the same time, like when stopped and such.
Maybe a heavy-duty clutch mechanism could be used to isolate it from the crank -- to sit/idle or EOC, and maintain A/C, Vacuum, Power Steering, etc. Hmmm. Decel charges the system and if the batts die during a trip, it's not a big deal -- de-clutch it and forget about it...
Plug it in when not in use. Good idea landspeed
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
