'97 Civic HX (Gen. 6).
I'm looking for the fuel injector power lead, a single wire for all injectors. Harness at injectors has individual wires for each cylinder so I don't want to cut all of them. This is for a fuel cut for EOC.
[EDIT]:
The +12V power to injectors is continuous when ign. is on. The grounds are individually controlled per injector. So my plan is to cut the +12V early in the circuit where it is still 1 wire for all 4 injectors. At the inj. rail it is 4 wires, all the same yellow+black color code. [/EDIT]
Found this 10-pin connector at drivers side fender, near firewall. Has a single very heavy black/yellow wire at bottom corner, both sides of connector. Is that it??
