Originally Posted by Gasoline Fumes
They're all cables.
thanks
I looked at a Chevy Metro listing on autozone and that vs the older Geo
cars didn't have a cable listed for replacment, absolutly all cable actuated?
Originally Posted by MadisonMPG
The 1.3L 5 speed is good on gas, not quite as good as the 1.0, but if you need the extra "hamster" you have it.
A/C isn't that rare nor is it super popular, but do you really need it? Get an XFi if you can. If you can't, get the 3.79/.59 transmission, 3tech economy cam, +10 cam gear and you should be good. Lower it an inch or two, block the grille, and you should be good.
I'd like a/c for the time the girlfriend is riding with me..
Humidity sucks out here in the summer time also..
Isn't the XFi an older model? older than 1996 (pre OBDII?)
If I regear it with the trans, cam and cam gear, will it be less powerfull or more torquey?
I'd be thrilled to death just to have a 35mpg combined vehicle..
![Smile](/forum/images/smilies/smile.gif)
